EK,
Coordinated motion (multi-axis along a straight line or path) is somewhat difficult from a C program as this is normally handled by the Trajectory Planner that runs on the PC. You would need to place "motion segments" in the Coordinated Motion Buffer and define how to accelerate along the path using a 3rd order parametric equation. See:
A simple straight line, single segment, constant velocity, 6 axes motion, from (10,10,10,10,10,10), to (20,20,20,20,20,20) over 40ms, using the console would be:
OpenBuf
Linear 10 10 10 10 10 10 20 20 20 20 20 20 0 0 25 0 0.04
ExecBuf
Maybe you could describe a bit more what you need to do. There may be a simpler solution. For example for a simple point to point straight line if you use the Independent Move commands, but scale the Max Vel, Accel, and Jerk proportionately to the distance each axis is to move, you should get a linear motion result.
Regarding linking C programs: we don't have a means of linking c modules. You could put the common code in a separate file and include the routines using a #include "c:\myfiles\foo.c" statement.
